Mk3 Mondeo needs new tyres
18 Oct 2002
Scun'orp
Always had Goodyear NCT's before, but is there a current favourite amongst Mondeo or similar owners? 205x55x16 size, normal use, nothing out of the ordinary. Looking to spend upto about £300 max on a set of 4.
You might be better off with a Touring tyre on a Mk3 Mondeo rather than something like a GS-D3 especially with that tyre size. Goodyear do others.
Fairly sure - 225/45/18 on mine
Edit - how queer, everything I can find says they should be 225/40/18, which is what's on the ST...I'm 99% sure what's on mine are 225/45 though, which are a lot more expensive!
