will my 550w power supply cope with xfire 5770's
24 Sep 2008
St. Neots, cambs
Hi there i have a 550w be quiet power supply and just wanna know if it will cope with 2 5770s.
I will be running a core i5 750 and blu rey drive and a couple of hard drives aswell.
thanks in advance for your help.
Single GPU 5770
System in IDLE = 228 Watts
System with GPU in FULL Stress = 321 Watts
Difference (GPU load) = 93 Watt
Dual GPU 5770
System in IDLE = 249 Watts (= 21W added over single GPU)
System with GPU in FULL Stress = 423Watts
Difference (GPU load) = 174 Watt
The monitoring device is reporting a maximum system wattage peak at roughly 425 Watts in CrossfireX (2-way), and for a PC with this setup, this is simply low and certainly remains within acceptable levels.
The tester did state his i7 system was power hungry with water cooling/lights so you could take off maybe 100w
