random errors, random colour screens with lockups , ect. i know it's not ram because i bought a 2gb stick but still same, also i've know idea whats the real temp of the cpu, because the sensor isn't working rightWhat kinda issues are you having?
Hvae you tried unlocking your current chip to turn it into a quad core?
I doubt very much that you would see much of a performance increase moving to the 965 from what you have atm.
i don't have another motherboard to try it..It would be a real shame if you were to buy the 965 and still have the same issues.
Can't you try the chip out in another mobo?
Maybe it's because your O/C isn't stable that you are having these problems?
i sold my 2 4850 to get the 5850..Hmmm, seems strange that the issues started happening after you got the 5850.
Have you tried using your previous GPU to see if the errors still happen?
Regarding the CPU temp, I have heard that certain BIOS'es can cause incorrect temp readings, if you haven't done already, you could try and update the BIOS to see if that sorts out the temp readings, if that doesn't fix it, then it is probably the temp sensor on the chip that is stuck, I don't think there is anything you can do about that though.
So something is breaking up.well the cpu was stable at 3.7ghz 1.4v then since i got the 5850 things started to go down hill,, i upped the cpu voltage to 1.425v which fixed for a week or 2 then it started again. so i droped everything to stock then everything was fine for 5-6days then it started doing it again..
i don't think so, a Tagan PipeRock 900w is more than enough..Do you think it could be your PSU?
my 720 won't unlock
but it can't be the psu because everything was fine when i had 2 4850, also 2 4850 uses more power than a 5850.Don't think he meant that your PSU isn't good enough, but maybe that it's faulty. This sounds similar to a problem I had a few years ago which was rectified by replacing the PSU. It's certainly worth testing with another if you can get your hands on one.
i've already tryed this mate.Sounds to me like an irq conflict after installing the 5850.
To eliminate this remove the soundcard and see if it still does it.
If everything is ok after you've taken the soundcard out,I'd try a full re-install of windows with the soundcard back in.
For stability I've found the Cat 9.10 driver to be about the best when using a soundcard instead of onboard sound.
Hope you get it solved.
gareth170 you must be bonkers to throw good money at a AMD Phenom II X4 Quad Core 965
- it may not solve whatever issue it is that your having
- the Phenom II X4 965 doesn't compete with the similar priced Core i5
as i said above, it can't be the psu because everything was fine when i had 2 4850, also 2 4850 uses more power than a 5850.At the very least I would spend a bit more time trouble-shooting before spending ££££, we all get hard-to-track-down glitches from time to time that make you tear your hair out but you have to man up and get down to business!
Would be good to get your PSU tested!![]()
I'm only trying to help you my friend, I think it's common sense to buy the best performing hardware you can for the budget yeah?don't care about if intel cpus are faster. i prefer amd/ati, thanks
Your really not thinking this through are you!IF it doesn't sole the problem i wouldn't be losing anything really because as i said i do a lot of video stuff, also i would have a spare cpu..
Listen, if you assume *anything* when it comes to troubleshooting your gonna be in a world of pain. You have to test every single component to be sure!as i said above, it can't be the psu because everything was fine when i had 2 4850, also 2 4850 uses more power than a 5850.
i know your trying to help mateI'm only trying to help you my friend, I think it's common sense to buy the best performing hardware you can for the budget yeah?![]()
getting a 965 is still an upgrade...Your really not thinking this through are you!![]()
i've just tryed a new 650w psu from a friend but it still does the same, i knew it wasn't the psu.. i've been using computers for about 23 years and been building them for 8-10 years but these issues i've never see before.Listen, if you assume *anything* when it comes to troubleshooting your gonna be in a world of pain. You have to test every single component to be sure!
I'm trying to help you, all my computers are working brilliantly and I don't have any hardware issues so I am spending my time trying to help those people who are stressing out with hardware issues . . .
If you wanna spend your way out this hole then be my guest, if you wanna get back to happy days then were here to help, good luck!![]()
