Deleted member 66701
Has no one thought of the obvious? Smash the window and take the hand brake off. I've done it before.
Simples!
Simples!
In Sheffield a few years ago the 47 48 bus route out of town went down a main road and then round a very tight side road. One day somebody had parked on the inside of the corner (double yellow). Bus was stuck for ten minutes (also blocking the main road), until about five people got out and bounced it out of the way, worked surprisingly well although the alarm did go off
Is their a wall right in front of the pavement, could you drive onto and down the pavement while nobody is about? (Engine might not have enough torque if the wheels are small)
Nothing behind it but 2 brackets (definitely won't take it and let the bumper back on), the boot (may take it and trap the spare wheel in the boot) and a fuel tank.
Serious reply:
Have you called the police yet. Pretty sure it's an offence to block someone's access to a public road, hence why it's illegal to park in front of someone's driveway if there is a car on the driveway at the time.
Engage low range, and select Reverse.
This works wonders with an HGV.... (and has done so in the past for me) I strongly advise you don't try this in a Car as they don't have steel girders for rear bumber bars. Ahem.![]()
Seriously, I hope the OP got sorted & he coated the offending car with brake fluid or similar.
Pinch/borrow a few dinner trays from the canteen, put one under each wheel using a jack/hired goons, then push the car out the way with your hands/car.the whole thing made me wonder what other options I had if I was in a proper hurry.
Pinch/borrow a few dinner trays from the canteen, put one under each wheel using a jack/hired goons, then push the car out the way with your hands/car.![]()
Brick the window, let the handbrake off move car, that's what I would do.
Remember, next time park where the other car did and leave a gap infront of you![]()
I don't think many people are going to risk a criminal damage charge in this scenario... I know I wouldn't.
Hmm, this would nearly work with the minor difficulty of there being no space between my car and their car to push at the front. Also, what's the chances of their alarm going off? (Presuming '55 Golfs come with alarm as standard) As I'm guessing it's pretty certain if you start doing that with the car!
Set the alarm off, might make the owner more likely to come out.
A bit late now dufus, see post 22.![]()
