You should know in 2-3 days!ill give it 2-4 weeks to see how it goes.
well im in no hurry tbh]You should know in 2-3 days!![]()
i've had 2 faulty cpu's in the past which i had to rmaI've never seen or experienced a faulty CPU before so I am intrigued . . . .
I suspect you were just looking for any *justification* to blow a wad on a new chip!![]()
Quote:
Originally Posted by el Kuarlos View Post
Out of curiosity Gareth, does yours run at 3.4 or another number close to that, mine is 3.392 (one of the multipliers is at 199.5 but not sure of the reason-signal its been oc'd maybe?)
its normal all cpus waver the speed, its to do with the motherboards generate clock, some do it slightly over & some do it slightly under.
mine is 3.41 at stock ,
