- 17 Oct 2002
- Stoke
*** *** Iiyama ProLite E2407HDSD 24" Widescreen LCD Monitor @ £159.99 inc VAT *** ***
The ProLite E2407HDSD is HDCP compliant and features true 16:9 High Definition 1920x1080 native resolution. Complimented with a blistering 2ms response rate and 60000:1 Advance Contrast Ratio the E2407HDSD really is, in a class of its own. Opticolour automatically makes calibrated adjustments to Contrast, Brightness and Colour Balance to suit your application needs. Analogue and Digital inputs guarantees flexible connectivity. Finished in a stylish Piano Black design, the E2407HDSD is sure to stand out amongst the crowd!
- Screen Size: 24" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 60000:1
- Brightness: 300cd/m²
- Response Time: 2ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- Dimensions: 560.0mm x 404.5mm x 220.0mm
- Weight: 5.0kg
- Warranty: 3 Years On-Site
Only £159.99 inc VAT.
ORDER NOW
- Weight: 5.0kg
ORDER NOW
