Escort Si wheels on R plate Corsa - doable?
7 Dec 2005
hey up guys,
i come here with an unusual question, i have a set of 15" escort si wheels from my previous estate, that i love the shape of, however, i'm looking to put them possibly on my corsa, ok to some that may not look right but i'm a fan of the shape.
is it possible? as such as a straight swap, or would they not go? if so i'd have to reluctantly sell, and not for much as tyres would need a replacement.
Depends on the PCD and offset, you can get spacers/adaptors to change this though
As above really...sure it can be done but you need to get the above info for both cars and see if by some (highly unlikely) chance they match or you're looking at some work to get them to fit.
You wont be able to do it..
Changing the PCD would work using adaptors
Changing the centre bore where the hub fits would work using adaptors..
Unfortunately the offset is too close to change. There simply wouldnt be enough space to fit the adaptor between the wheel and the hub. If you did fit them the wheel track would be significantly wider and the wheels would foul the arches.
http://www.fk-automotive.com/
they do quite a wide range of adaptors.
