Halfords staff with cars are like PC World staff with knowledge on computers.
I buy from overclockers as the staff in the shop know what they are on about.
If you are re-using the ball joint, don't use a splitter, they kill the rubber.
Who uses a "ball joint splitter" these days anyway??
Too late.
I don't see how a ball joint can be removed wihtout damaging the rubber... especially a lower one where there's no room to get a scissor type in.
Obviously a DIY type!
Ball joints are freed by one or two decent 'taps' of a hammer to the housing.
No damage to the housing, rubber gaiter or thread of said joint.
I'm a time-served techinican 20yrs+ and don't own one.
Nut splitters? Never used one. Is the bottom of said spinning joint facing downwards? Simply exert some careful upward pressure from a jack to stop the joint spinning in it's taper and undo nut.
The nut came down right until the end of the shaft.. and then it started to turn the whole joint.. Will experiment with a jack tommorrow, not sure how I can apply a jack underneath and still have room to remove bolt though.
Is the nut on top of the steering arm on the hub or below, facing down?
Facing up makes it easy as a jack can be placed underneath the joint, forcing it up into the taper, making nut removal easier. Would be good to lubricate the threads and perhaps wind said nut back down before attempting to undo it again.
  )   Learn something every day.  And i did wonder how it could hold it's integrity when doing what I expected it to do  ..Ah, bugger that makes it more difficult.
Using air tools in this case does make it somewhat easier.
Freeing [taper] ball joints with a large hammer is a well known trade 'operation' versus a splitter.
