Is an expresscard slot valuable nowadays?
Man of Honour
19 Oct 2002
Surrey
I was wondering whether it is a useful port to have nowadays? I honestly can't think of a reason I'd need one?
It was so useful Apple removed it from all the MacBook Pro range apart from the 17", and installed SD cards slots instead.
there are a few docking stations that connect via the ExpressCard slot, but can't really think of anything else you'd use it for
If you ever want to install a TV card, better sound card or a card to give you more USB/Firewire ports then it'd be useful. Then again you could probably just get them in their USB variant anyway.
They have been around for 2 years at least!
Yea i know they have been out for awhile. Think the new ones are meant to be faster and more secure or something:
http://www.engadget.com/2009/12/03/verbatim-announces-worlds-first-ssd-expresscards-with-256-bit/
Also noticed this that popped up. Bit bulky, but still it adds USB 3.0 support, albeit slower than a native slot on a motherboard:
http://www.engadget.com/2009/12/07/usb-3-0-expresscard-adapter-promises-more-than-it-can/
