Wow, it cost £6000 to fix?? What needed doing? I thought you just scraped the hedge?
I did.
And the metal post inside said hedge which monged the entire rear suspension
[TW]Fox;15477593 said:I did.
And the metal post inside said hedge which monged the entire rear suspension![]()
My plan is to cancel my insurance when I'm 25 in a couple months (for a £26 fee) and then get more quotes and a difference insurance, should drop by a couple hundred or so...
Why would you do that? surely you wont get this years NCB added to your overall NCB.
Because I've only had the car for 3 months, and I'm 25 in another 2, so I'd rather cancel and save a few hundred and then get my NCB after this year. Would I save more in the long run by wating another 7 months and getting my NCB? Not got any NCB as this is the first car I'm actually insured on under my name.
How about you call around before canceling and make an informed decision then.
Depending entirely on what you drive 1 year NCB may be more beneficial than being 25 for your first year in the long run.
So you would rather start again at 25 with 0 NCB, than wait 7 months and have 1 years NCB.
Oh, and I remember why I got my insurance much cheaper through Direct Line, it's because they gave me the insurance price for someone with a 3yrs NCB (some offer they do if you have no NCB) and the guy who I spoke to at Direct line said it would work out better for me if I then cancelled when I turned 25 and re-applied with 0 NCB.
You being sarcastic or genuinely intrigued?
[TW]Fox;15477572 said:£2k for a 525d at 24![]()
Either way it's minor to me if you don't believe me, but if you want more info I basically found out by doing my quote on their website, I was trying to find out how much discount a NCB would have got me and when I put 1yr NCB it went up! This didn't make sense to me (obviously) so I put it up some more and basically figured out that it worked out cheaper for a 0 NCB than a 1-2yr NCB.
When I spoke to the Direct Line on the phone I asked if they could do anything to reduce the cost as I'd be turning 25 in 5 months and he said that the price wouldn't increase much at all when I hit 25, but then I told him I got a quote for being 25 from their website and it was a few hundred quid cheaper, he then said he didn't notice that I hadn't got any NCB and then advised me on the whole cancel when you turn 25 and then re-submit... No idea how the discount is issued but it still led me to the conclusion of a 3yrs NCB offer.
Most insurance companies will start a new driver off with a few years NCB, certainly was the case 'when I were a lad'If this is not the case anymore then it might be worth holding onto the insurance as at the end of the year you'll have 4 years NCB.
That OK for you?
