It's £72 for the cambelt kit inc pulleys + labour of course. Getting my Mk1 done on the 22nd.
How much is labour and why are you not getting the waterpump done?
Or does the kit have one in?
It's £72 for the cambelt kit inc pulleys.
Poor Howard and his LWSCId ask freelance mazda about it first though just to make sure!
Have i missed something? His hasn't failed, failiure is generally due to the cambelt being changed incorrectly and can affect all 3 types of crank, the earlier cars are just more prone to it.
Should I really get the water pump done? Its got 70k on the clock, I assume its a Mazda reccmendation to get it done at the same time?
I know someone selling a Mazda MX-5 Eunos. It is an 18yr old limited V-spec edition. Has about 160000 miles on the clock which isn’t bad for its age. Leather interior and glass back screen which is rare. Has a new cd/mp3 player in it. Tax and Mot till next spring. Also its British Racing Green. They want £1800 for it if your interested.
It may well go for another 170k miles as it is not a service item, but you need to take the cambelt off to replace it, so if your doing one you may as well do the other.
In fact a cambelt is less likely to kill your engine on these than the waterpump, not that this is saying much.
Thermostats generally don't go, and are easy to replace, if it's fine, leave it.
Use an OEM oil filter as it has a non return valve.
Personally why it's all off and apart i would change the rocker gasket, and the 2 o rings as well as the aux belt.
An OEM w/pump - £40
Aux belt, o rings and rocker gasket - £35
Do this and your good to go, the gaskets and o rings won't last forever, but they are cheap and easy to fix.
Also check your clutch slave, £15 part, easy to change and stops you getting stranded (or buy one to keep in the glovebox).
EDIT: i have a braided clutch line, no point unless yours has failed (which is unlikely) and the same again for the braided brakes, if yours are shagged go for it, but i doubt you will notice any difference over working oem ones.
In fact a decent brake bleed with good fluid will have more effect (on this car).
What oil are you using?
snip
