Best ISO mount daemon ?
27 Oct 2006
London
Windows 64bit Ultimate.
Installed Power ISO which I've discovered to have horrendous memory leak issues.
I'll try to install my trusted daemon tools again.
Anything else I should try - preferably free ?
Many thanks
If I've understood the question correctly that you want to mount an ISO that's on your hard drive then i'd recommend Virtual Clone Drive.
Taff
Another vote for Virtual Clone Drive.
Was using daemon tools but i was having problems with win7, tried VCD and never looked back :)
Works fine with Win7 64bit
Daemon tools is shocking, they can't even make their own driver, and they bundle spyware with the installer. I refuse to use any software that chooses to bundle spyware (even if it is optional)
Virtual Clone Drive for me
