- 28 Jun 2006
- Newcastle upon Tyne
Hi all,
I am currently using a PC which I buil when the Conroe CPUs first came out and, apart from the occasional hiccup, it has served me well. The problems that have occurred have been resolved reasonably quickly (in most cases
) but the latest has got me stumped. The spec is an E6400, 2gig RAM, Windows XP, an 8800GT (running two monitors) on a Gigabyte DS3 mobo.
I have not added any hardware since a new graphics card at the end of last year.
My machine has started hanging. It's a strange kind of crash that started at the back end of last week and I have tried just about everything to fix it. My PC basically stops doing anything - if I'm in mid-browse or playing a game, it will just stop. My mouse will still work and if I'm in-game my sound will loop. Opening Task Manager occasionally works, but it doesn't let me actually shut down any applications or processes. I can also occasionally hit the Windows key + L, and then shut down my PC from there - but not always perhaps 1 in 5 times). I can even usually click icons on the desktop and they will highlight, but I cannot acctually run them. If I continue to click around and try to get things working, then about 50% of the time, it will start beeping insanely to get me to stop. No matter what, it requires a reboot to get back into things.
My first real problem (without knowing what I was in for!) was with the USB headset - the mic was intermittent, but sound was fine. It was around this time that the crashes started. So I disabled the headset and moved over to my soundblaster (which has never had a working input)....and then I changed over to the mobo sound and mic, removing the soundblaster. The crashes continued.
Oddly enough, the crashes do not happen when playing L4D2 as often as they do in Plants vs Zombies, despite L4D2 probably being a lot more intensive and tough on the system.
I have run Ad-Aware, Spybot, AVG, Windows Defender and Memtest - nothing has flagged up. Various programs and the BIOS indicate that overheating is not the issue (CPUs hovering around 52 under pressure, GPU slightly more, but not alarmingly). I have also tried accessing the internet wired instead of the Netgear WG111T I have (which has been a pain since day one).
I just cannot understand what the problem is. I'm at my wits end and so have copied a lot of my most important files over to an external HDD in preparation for a full wipe (I did one at the tail end of last year, so I doubt it's just clogged up).
I would appreciate any advice that might help me sort my problem out...
