12 Dec 2009 at 21:33 #1 miniyazz miniyazz Soldato Joined 25 Dec 2008 Posts 5,976 Location Sheffield/Norwich Title says it all Expound your bountiful knowledge upon me
12 Dec 2009 at 21:36 #2 CliffyBiro CliffyBiro Caporegime Joined 1 Mar 2008 Posts 26,303 Only when they're leaking, surely? I know it works for leaky sunroofs.
12 Dec 2009 at 21:44 #3 miniyazz miniyazz Soldato OP Joined 25 Dec 2008 Posts 5,976 Location Sheffield/Norwich Hmm, I'll be doing that for my sunroof then I was more thinking with regards to cold weather - is it a good idea to grease up the seals if there's frost and the doors are sticking?
12 Dec 2009 at 21:47 #4 MrMoonX MrMoonX Permabanned Joined 31 Dec 2007 Posts 10,033 use gummy pfledge
12 Dec 2009 at 23:22 #5 Dogbreath Dogbreath Soldato Joined 18 Oct 2002 Posts 16,659 Location Devon It's never worth it as Vaseline rots rubber.
12 Dec 2009 at 23:36 #6 miniyazz miniyazz Soldato OP Joined 25 Dec 2008 Posts 5,976 Location Sheffield/Norwich Dogbreath said: It's never worth it as Vaseline rots rubber. Click to expand... Ah ok.
12 Dec 2009 at 23:55 #7 Biohazard Biohazard Permabanned Joined 29 Aug 2003 Posts 31,330 snort it instead
13 Dec 2009 at 00:02 #8 [TW]Fox [TW]Fox Man of Honour Joined 17 Oct 2002 Posts 160,334 MrMoonX said: use gummy pfledge Click to expand... This. It's £6 from BMW and obviously works on all makes of rubber seal. Dogbreath said: It's never worth it as Vaseline rots rubber. Click to expand... This also.
13 Dec 2009 at 10:10 #9 miniyazz miniyazz Soldato OP Joined 25 Dec 2008 Posts 5,976 Location Sheffield/Norwich Cool, cheers guys.
13 Dec 2009 at 11:44 #10 Disco Boy Disco Boy Soldato Joined 4 Aug 2009 Posts 5,310 Location London Use a water based lubricant, not Vaseline as it will dissolve the polymers in rubber. It also applies for "rubbers" if you know what I mean.
13 Dec 2009 at 13:02 #11 Barry Smalley Barry Smalley Associate Joined 18 Oct 2002 Posts 2,493 Location Tinternet Disco Boy said: Use a water based lubricant, not Vaseline as it will dissolve the polymers in rubber. It also applies for "rubbers" if you know what I mean. Click to expand... KY
14 Dec 2009 at 11:41 #12 VFR_KID VFR_KID Soldato Joined 3 Jul 2008 Posts 3,248 Location Fife way up in Scotland Barry Smalley said: KY Click to expand... Eye slap a bit KY jelly round your seal LOL. Best shouted to the wife in a busy street. "Im just away to put some KY on your seal darling"
14 Dec 2009 at 12:12 #13 AmDaMan AmDaMan Soldato Joined 18 Oct 2002 Posts 4,023 Location Wellington, NZ Sillicone based grease from anywhere should be ok. I used some spray stuff from Halfords when my roof started leaking and it's not done it since
14 Dec 2009 at 14:20 #14 miniyazz miniyazz Soldato OP Joined 25 Dec 2008 Posts 5,976 Location Sheffield/Norwich Okie dokie ta
14 Dec 2009 at 22:09 #15 ToLearn ToLearn Associate Joined 19 May 2005 Posts 400 Location shropshire Wurth Rubber Spray very good product
