Hey Guys,
This is my first post. I would like some advice and help please.. Let me first off start with the hardware I have used to build my new PC..
*OVERCLOCKED* Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz @ 4.00GHz Max / Gigabyte EX58-UD5 Intel X58 Motherboard / Corsair XMS3 6GB PC3-12800C9 DDR3 / Corsair H50-1 Bundle from overclockers.co.uk
Antec P183 Case
Sapphire 5770 1GB New Edition
Corsair 1000W Power Supply
2 x 1.5 TB seagate 7200 RPM 32mb cache for storage
1 x Curcial M225 SSD (64gb for installing Windows 7 Home Premium 64bit)
Well after building this beautifull machine today I finally got to install windows 7 home premium 64bit on my Crucial M225 SSD..
Thorughought the inital installation it was very very slow.. I mean it took almost 3-5 mins just to get to the language selection part and then it took approx 15 mins to install windows all the way to the startup..
After the start up things seemed pretty smooth.. I did not install any drivers .. just did a windows update from windows update and then installed my graphics card drivers..
Is it normal for widows to install so slow? Is there some kind of error? On my motherboard the LED Display is showing FF once windows is up and running..
Does everything seem to be ok or is there something wrong?I know it's kind of hard to tell without seeing it in the flesh but would appreciate all help and advise..
Also how do I know that my CPU has actually been clocked to 4.00GHZ and my Ram has been clocked.. is there anywhere I can check this?
Also those of you who own the Crucial M225 what is that little white jumper switch on the top and do I need to do anything with it..
Thanks all
Antec P183 Case
Thanks all
