- 11 Dec 2009
I'm getting myself a new pc for Christmas and I've set a budget of £800 maximum. I don't need monitor/keyboard/mouse/speakers/windows - just a base unit.
My current pc is:
Athlon64 3500
2GB RAM
Geforce 6800 GS
Asus AEN-E (Nforce 4)
It works perfectly well for most things however its now right at the bottom of the spectrum for gaming (L4D2 works but isn't exactly pretty), cant possibly run games in my monitors native res (1920x1080) and is likely to have the motherboard die at some point next year (I'm on my 3rd A8N-E board in 4 years).
I'm not bothered about overclocking, I'll be using it for occasional gaming and general use so I don't need a completely top-end machine. My main requirements are that it'll run current games well, will last reasonably well for 4 years (I usually get a new pc after that) and will be quiet in normal non-gaming use (noisy pc's drive me crazy).
I've built plenty pc's in my time but haven't been keeping up with the technology for the last few years so I dont know whether to go for Athlon, i5 or i7. I'm perfectly happy to build my own but was thinking that I might just get one of the ocuk pre-built systems this time unless I'd save a decent amount by self-building.
I was looking at the Titan Goliath i7, but the fact that its overclocked made me wonder about its noise levels. Given my rather ridiculous requirements would any of you kind souls be able to suggest something suitable?
My current pc is:
Athlon64 3500
2GB RAM
Geforce 6800 GS
