Ok - I'll drop the tRD back to 7 which the mobo would select on Auto (latency changes by around +10% with tRD 6 to 7. If I can get a clean test at that setting then we are heading in the right direction.
After much research I think I've got all the correct timings although a few may be loose - Im waiting for an email from OCZ to list me the correct settings for my mem and mobo.
~Scotty
~Scotty
 LinX, Intel burn test,Everest all run for hours with no probs. Then Prime BSODed me in seconds. I tinkered but couldnt get past 3rd test so I dropped down to 3.5GHz ......then to 3.4GHz before I could run 13 tests without error. Going to have to rethink this situation!! Is the small FFT test only cpu intensive?
