The criminal was at liberty to commit this crime after 50 previous convictions, and you have faith in courts?
courts can only go by guidelines set out by government.
Four men including, as the jury found, the two of you, armed with weapons then proceeded to carry out a dreadful, violent attack upon him when he was defenceless on the ground.
That attack involved kicking and punching him, stamping upon him and striking him with weapons, including a hockey stick and a cricket bat.
The witness, Miranda McCloughlin, who was at the window immediately adjacent to where the attack was taking place pleaded with you and the two others to stop, telling you that you were going to kill the man on the ground.
She was disregarded and the attack continued. She described you and the other two men involved as acting like a pack of animals. It is purely fortuitous that the man Salem was not killed.
MAYBE reasonable. You can't just attack them. If they try resisting then you can start using more force
Whilst I agree beating them over the head to give them brain damage is not reasonable, I'd happily chase someone/rugby tackle them and incapacitate them - by that I mean stop them from running off and being able to stop them from escaping until the police come. If it means using more force you can bet your bottom dollar I'd use it!
I'd suggest the Court probably considered this too - they certainly had time it appears to collect a small group of people, armed with various weapons and then pursue, unless they just happened to find a cricket bat, hockey stick and metal pole lying on the ground where they ended up.
Faith in Courts >>> Faith in Media reports every time.
And is even backed up by the JudgeI agree with that, I had a problem with him saying you can give them a blow to the head regardless of the situation and it would be legal.
The prosecution rightly made it plain that there was no allegation against you, Munir Hussain, in respect of the force you used against Salem in defending your own home and family or of the force used by either of you in apprehending Salem.
Well since we have no information to the contrary, let's assume that the media reports are accurate. Tbh it wouldn't be that unusual to find a cricket bat or a hockey stick to hand in a British Asian's home, a metal pole could have any number of uses.
the guy had a knife, how do you defend yourself against that? you jsut hold his legs and get stabbed to death... he will not lie there he will at least hit out, kick bit you... you will fight back and possible either end up dead or in the same situation as mr hussain...
the best advice would be jsut to let him go (despite my thought about what should happen to him)
I feel little sympathy for him.
[TW]Fox;15529836 said:Would you guys support me if I beat some guy to death after I saw him climbing into the garden?
I doubt anyone does. That doesn't mean we should legalise revenge attacks though, or that Mr Hussain should not receive the term he did.
Devils advocate obviously, point being, where do you draw the line?
but I think more often than not the law isn't tough enough on real criminals.![]()
...seems like the victim gets a harsher punishment than the offender.
