[TW]Fox;15535963 said:You need to find out where the coolant went.
And how does one do that?
http://forums.bimmerforums.com/forum/showthread.php?t=1068015
Is it really that simple to drain and replace the coolant?
[TW]Fox;15536095 said:No, it is not that simple to drain and replace the coolant because these engines are an absolute nightmare to bleed properly and if you don't bleed it right first time you can get overheating problems, airlocks, etc etc. It's a complete faff.
As for the sensor it should be obvious if the sensor is faulty, when you opened the header tank where was the level?
dear oh dear £135 to replace coolant that costs about £20..
