 - 11 Sep 2008
 - Co. Durham
17,100?
My Asus 5770s score 16,014 @ 999core and 1300memory
yeah mate not bad huh well 17,106 to be exact
17,100?
	looking at these results you lot are showing how many are running an amd cpu ? , seems the later intel cpu's are the best for benching yes ? . but how better are they compaired to the fastest phenom II's ? , so you need a fast cpu to get the best out of these gfx cards ? , i was told dont be stupid at guru3d's forum but then i said why do all the reviewers use the fastest intel cpu's overclocked instead of the fastest phenom's ? . some of these results put my cf 5770's score to shame lol
HA HA no mate i cant remember the exact speeds think it was 1010/1310 1.25v however one thing i did find is these cards do not always crash or artifact before the performance goes down. some people that run 1400+ mem will find that my 1310 will bench and perform far higher just like the i7's there is defo a sweet spot rather then faster the better. Took me a week of benching to find my sweet spot.
Yes! You're spot on there.
I upped my Memory from 1300 to 1400 and noticed that I got less performance in Vantage, so its back down to 1300 for me![]()
  Ha Ha, you cheeky little numpty, you kept that information quiet didn't you![]()
just tried at 1000/1300 and get 18377 marks, and 17055 gpu marks
bah I have to redo the bencies again
cheers for bringing it up BigBruiserAl
lol
so it seems there's some throttling going on, is it temperature, or like overspeed protection of some sort! a bios hack is needed
I feel dirty and cheated, time to sell these now![]()
As mentioned in the HD 5870 article, overclocking the memory on these cards is quite different from any other card so far. Normally you'd expect rendering errors or crashes, but not with these cards. Thanks to the new error correction algorithm in the memory controller, every memory error is just retransmitted until everything is fine. So once you exceed the "stable" clock frequency, memory errors will appear more often, get retransmitted, but the rendered output will still look perfectly fine. The only difference is that performance drops, the further you increase the clocks, the lower the performance gets. As a result a normal "artifact scanning" approach to memory overclocking on the HD 5800 Series will not work. You have to manually increase the clocks and observe the framerate until you find the point where performance drops.
Guys,
Just fitted a vapor-x version in the wife's PC which I'm building her for Christmas, which I selected after I found the original XFX reference design 'shroud' was too loud. She wanted a quiet PC, and I don't think the v1 cooler really fits the bill. The vapor-x version is definitely worth the extra though as it's practically silent in comparison.
I've got 2 5770's in mine with the shroud and never hear em?!?!
