Hey all.
Wanting to know if a dual rad would be sufficient for overclocking my i7 920 ?
As i can most likely fit a dual in quite easily into my case however a tripple i cant seem to figure out a way i could get it to fit.
The case im using is a xaser VI
EDIT oh also
Would there be anything "bad" about putting the radiator at the bottom of the case ?
It has a 3cm gap between the case and where the table is ?
EDIT oh also
