- 17 Oct 2002
- Stoke
*** *** Alienware M15x Intel Core i7 720QM 1.60GHz 15.6" LED Laptop - Windows 7 Professional (Cosmic Black) @ £1,599.98 inc VAT *** ***
Take control of the game once and for all with the Alienware M15x. Grab the reins of this 15.6" powerhouse with blazing-fast graphics, the latest in processor technology and high-definition capabilities all in a devilishly sleek design. The Intel Core i7 mobile processor will take you even further with features like Intel's Hyper-Threading and Turbo Boost technologies that power through games and multimedia applications all at the same time.
The M15x’s case design protects your world with aggressive lines and an in-your-face attitude that quickly dissipates system heat and looks good doing it.
Alienware Command Center provides intuitive, user-friendly access to exclusive applications and controls, including AlienFX lighting effects software and the AlienFusion power management system. Updates and new releases download directly into Command Center, creating a constantly evolving tool for modifying and personalising your M15x.
Stealth Mode is designed to throttle back the CPU and GPU to decrease the energy consumption and noise output of the M15x. To engage Stealth Mode, simply use the Stealth Mode odometer, conveniently located above the keyboard with the touch-sensitive controls.
- Operating System: Microsoft Windows 7 Professional 64-Bit
- Processor: Intel Core i7 720QM 1.60GHz 6MB Cache
- Graphics: Nvidia GeForce GTX 260M 1024MB
- Memory: 4GB DDR3 1333MHz RAM
- Hard Drive: 500GB SATA (7200RPM)
- Optical Drive: Blu-ray
- Bluetooth: Bluetooth 2.1 + Enhanced Data Rate
- Screen: 15.6" Full HD LED Widescreen (1920x1080)
- Wireless LAN: 802.11b, 802.11g & 802.11n
- Ethernet LAN: 10/100/1000
- Sound Controller: High Definition Audio
- Speakers: Stereo
- Expansion: 54mm ExpressCard Slot
- Card Reader: SD Card, Memory Stick, Memory Stick Pro & MultiMedia Card
- Camera: 2.0 Megapixel
- Security: Kensington Lock Slot
- Connections: 2x USB 2.0, 1x USB 2.0/eSATA, 1x IEEE 1394a, 1x DisplayPort, 1x VGA, 1x RJ-45, 1x Microphone & 2x Speakers/Headphones
- Battery: 6-Cell Lithium-Ion
- Dimensions: 377.93mm x 308.51mm x 48.70mm
- Weight: 4.08kg
- Warranty: 3 Years + Accidental Damage Support
Only £1,599.98 inc VAT.
ORDER NOW
- Speakers: Stereo
- Weight: 4.08kg
ORDER NOW
