I hope someone can help me with a problem I'm having - when I press the power button I'll get a single short beep suggesting everything is ok, then...
Sometimes it'll freeze during POST at:
PC2-6400 Dual Channel Interleaved
Initializing USB Controllers .. Done.
If it manages to pass this point it'll sometimes freeze at:
Checking NVRAM...
On a couple of occasions it hasn't beeped at all and my monitor remained in standby. If I perform hard resets it will eventualy boot.
I ran memtest overnight and it found no errors.
I ran orthos overnight with no issues.
I have removed, cleaned and reseated memory and video card with no improvement.
I have tried disconnecting all drives and USB devices and issues remained.
The strange thing about this is that once I get it to boot to Windows I can switch off and restart and it'll behave perfectly unless I leave it switched off for a few hours, and I can keep the computer switched on for a week or more with no errors. It's like the exact opposite of overheating. The computer has been running at current spec for two, maybe three years. Nothing is overclocked.
In testing I think I've ruled out everything except motherboard and PSU. As the computer is running perfectly after passing POST from cold it's hard to know what to do next. As it's often hanging at 'Checking NVRAM' could this be due to a dodgy BIOS chip?
Any ideas of what to test next, or suggestions of what may be at fault would be greatly appreciated...
Spec is
Asus P5W DH Deluxe
Core2Duo E6600
4x1GB Corsair XMS6400 DDR2
Sapphire Radeon HD 4670 Ultimate
Seasonic S-12 600W (I think)
Thanks in advance.
Checking NVRAM...
Spec is
Asus P5W DH Deluxe
Core2Duo E6600
Thanks in advance.
(I know you say it isn't usb related).
