Asked to call MS on 3rd install of Win7
26 Jul 2003
Loughborough
I understood with Win 7 Retail I could install as many times as I wanted, provided I only had one active copy.
I have been upgrading my system and did the third install tonight and had to phone for a code. During the call I have to indicate how many systems I had it running on.
Is this unusual or do I have to do that every time from now on?
There may be a time scale associated with the activations - it's only just come out so this must be your 3rd activation in a couple of months.
3 in a couple of months is a bit suspect for a new piece of software. You're probably limited to 3 a year for none-interactive activation. But as you said, you rang up and it's all fine.
Will just be a time issue to be honest.
When I replaced a hard drive a week after my initial windows 7 install, Microsoft wanted me to call for a code. :rolleyes:
Anyway, no real problems... Just a bit of a pain and a little time consuming :(
Must be the fact its 3 installs in 3 weeks...
1) Original Core 2 Rig
2) Core 2 with 5850
3) i5 with 5850
Anyway, I imaged it after installing this time so hopefully that will save the hassle next time..
2) Core 2 with 5850
3) i5 with 5850
Call me crazy here, but given that you get 30 days grace (well more if you slmgr -rearm), why would you activate a system that you know you are upgrading in a week? :confused:
How bizzare, I'm on an OEM Win7 Upgrade copy that MS sent out, and I've reinstalled about 10 times now in a month due to testing and trying to eliminate a stutter I was getting (Nvidia GPU driver caused so a bit stuck with it til it's fixed, but sorted a workaround now), and I haven't once been asked to call up and activate, which really surprised me.
you can install and activate as many times as you want as long as its the same mobo, you wont have to call them. Thats my experience anyways
