Well ive tried running the PC bare minimul stuff and another perfectly good G card, and power is going thru, everythings getting power but nothing goin thru to the screens, i dno if its the mb aswell but my CPU is missing a pin as i jus noticed =/
Socket AM3 has less pins than Socket AM2+
its not a bug its a future![]()
now i mean a pin is actually missing, yo can see were it should be but theres nothing
So why the hell are you moaning about your gpu having probs.
You said you had similar problems with your GTX 295, if pins are missing out of your cpu, then why are you moaning about the same probs with a 5970.
Just get your cpu replaced, then if you have the same problems, you would have a legitimate gripe.
"CPU is missing a pin as i jus noticed =/ "
Please read before having a go at me sir. It wasnt something i planned on discovering =[
That post that you are quoting, was posted about 2 hrs ago.
It's not rocket science that you should have realised by now the problem is not the gpu, but the cpu.
All you had to say was that, it may well be the cpu, not the gpu.
And i have read the whole thread, which is obviously more than you have done including your own posts.
