Need some very easy vbscript help (see inside)
1 Dec 2004
S.Wales
Im creating a xmas opening script using vbscript to bolt onto our VoIP system call routing script. It all works perfectly. I have posted a section of the code below:
Code:
Function CheckDateTime(current)
	current = CDate(current)
	' Prepare useful variables...
	Dim xday, xmonth, xhour, xminute
	xhour = Hour(current)
	CheckDateTime = 0
	'Normal working day
	If (xhour >=8 and xhour <17 and xminute<30) Then
		CheckDateTime = 1
	End If
	'Christmas period
	If (current >= CDate("24/12/2009 12:00PM") and current <= CDate("04/01/2010 08:00AM")) Then
		CheckDateTime = 2
		'25th December
		If (current >= CDate("25/12/2009 00:01AM") and current <= CDate("25/12/2009 23:59PM")) Then
			CheckDateTime = 3
		End If
Concentrate on the section
Code:
'Normal working day
		CheckDateTime = 1
	End If
Would this be the correct way to represent 08:00 > 17:30 ?? I know the 08:00 > 17:00 works fine, but I added the xminute as our actual closing time is 17:30.
Will this work or will I have to represent this 30 minutes another way?
I would have thought that would only work at the following times:
8:00-8:29
9:00-9:29
10:00-10:29
I would try:
Code:
'Normal working day
	If (xhour >=8 and xhour <17) Then
		CheckDateTime = 1
	Elseif (xhour =17 and xminute <30) Then
		CheckDateTime = 1
	End If
Which would cover 8:00-17:00, and then 17:00-17:30 as two separate scenarios.
Hi,
Code:
If (xhour >=8) and (xhour <17 and xminute<30) Then
Should do it (up until 5:29pm anyway).
Can't see where you are setting the xminute though?
8:00-8:29
9:00-9:29
10:00-10:29
I would try:
Code:
'Normal working day
		CheckDateTime = 1
		CheckDateTime = 1
	End If
Thanks for this, I shall give it a blast tomorrow :)
I created this script over a year ago for a company i used to work for who had about 6 call centres each with very annoying opening times/closing times/routing to mobiles etc
So frustrating :(
Least ours is simples :)
"Its xmas, naff off :D"
I would try:
Code:
'Normal working day
		CheckDateTime = 1
		CheckDateTime = 1
	End If
This works great :)
Thanks
Ahh, there we go, slight modification needed, here is the full script for those interested
Code:
'Copyright dmoranda.co.uk
TestCase(Date & " " & Time)
Testcase("23/12/2009 8:00AM")
Testcase("23/12/2009 17:00PM")
Testcase("23/12/2009 17:35PM")
Testcase("24/12/2009 8:00AM")
TestCase("24/12/2009 12:05PM")
Testcase("25/12/2009 8:00AM")
Testcase("26/12/2009 8:00AM")
Testcase("27/12/2009 9:00AM")
Testcase("28/12/2009 10:00AM")
Testcase("29/12/2009 8:00AM")
Testcase("30/12/2009 8:00AM")
Testcase("31/12/2009 8:00AM")
Testcase("01/01/2010 8:00AM")
Testcase("02/01/2010 8:00AM")
Testcase("02/01/2010 17:59PM")
Testcase("02/01/2010 18:01PM")
Testcase("03/01/2010 08:00AM")
Testcase("03/01/2010 18:01PM")
Testcase("04/01/2010 06:00AM")
Testcase("04/01/2010 08:01AM")
Function TestCase(datetime)
	MsgBox "Outcome for " & datetime & " = " & CheckDateTime(datetime)
End Function
' This method returns true if the service will be open at the specified date/time, or False if the service will be closed.
'1 = Call goto Agent, 2 = Call goto TAS, 3 = Call goto office closed annoucement
	xminute = Minute(current)
	CheckDateTime = 0
	'*Use the below code if closing time falls on the hour*
	'Normal working day
	'If (xhour >=8 and xhour <17 and xminute<30) Then
		'CheckDateTime = 1
	'End If
	'*Use the below code if closing time falls during the hour*
	'Normal working day
		CheckDateTime = 1
		CheckDateTime = 1
	Else
		CheckDateTime = 2
	End If
	'Christmas period
		CheckDateTime = 2
		'25th December
			CheckDateTime = 3
		End If
		'26th December
		If (current >= CDate("26/12/2009 00:01AM") and current <= CDate("26/12/2009 23:59PM")) Then
			CheckDateTime = 2
		End If
		'27th December
		If (current >= CDate("27/12/2009 00:01AM") and current <= CDate("27/12/2009 23:59PM")) Then
			CheckDateTime = 2
		End If
		'28th December
		If (current >= CDate("28/12/2009 00:01AM") and current <= CDate("28/12/2009 23:59PM")) Then
			CheckDateTime = 2
		End If
		'29th December
		If (current >= CDate("29/12/2009 00:01AM") and current <= CDate("29/12/2009 23:59PM")) Then
			CheckDateTime = 2
		End If
		'29th December
		If (current >= CDate("30/12/2009 00:01AM") and current <= CDate("30/12/2009 23:59PM")) Then
			CheckDateTime = 2
		End If
		'30th December
			CheckDateTime = 2
		End If
		'31st December
		If (current >= CDate("31/12/2009 00:01AM") and current <= CDate("31/12/2009 23:59PM")) Then
			CheckDateTime = 2
		End If
		'1st January
		If (current >= CDate("01/01/2010 00:01AM") and current <= CDate("01/01/2010 23:59PM")) Then
			CheckDateTime = 3
		End If
		'2nd January
		If (current >= CDate("02/01/2010 00:01AM") and current <= CDate("02/01/2010 23:59PM")) Then
			CheckDateTime = 2
		End If
		'3rd January
		If (current >= CDate("03/01/2010 00:01AM") and current <= CDate("03/01/2010 23:59PM")) Then
			CheckDateTime = 2
		End If
		'4th January Early Morning
		If (current >= CDate("04/01/2010 00:01AM") and current <= CDate("04/01/2010 08:00AM")) Then
			CheckDateTime = 2
		End If
		'4th January Working Day
		If (current >= CDate("04/01/2010 08:01AM") and current <= CDate("04/01/2010 17:30PM")) Then
				CheckDateTime = 1
		End If
	End If
End Function
Code:
	'Normal working day
		CheckDateTime = 1
		CheckDateTime = 1
	Else
		CheckDateTime = 2
	End If
