Sorry to hijack but it's similar, is it possible to get a VGA splitter? If so, would it affect the quality of the XBox picture?
I thought there was big problems using HDMI splitters because of HDCP?
I might be wrong but I think you need a switch rather than a splitter.
I've found a HDMI over CAT5 amplifier which does 1080p upto 30m and handles HDCP. Available on ebay for £40 BIN. Might give that a go. Anyone else got one of these?
This was supposed to be a feature of the PS3 before it came out - I remember Kutaragi bragging about how you could connect several HDTVs to one PS3 (as it had several HDMI ports which have since been removed) but that never saw the light of day. It was also claimed that it was possible to have all the games running at 1080p at 120 frames per second, for each HDTV. That never saw the light of day either.
EDIT: I see you went with it. What brand did you get? Does it do IR passthrough and optical?
I'm using it with a PS3 so I don't need IR passthrough. And do you mean optical for surround sound?
