- 13 Jan 2004
- Leicestershire
hi all... right i have a y reg ford focus and a slight issue with the electronics brought on (i guess...) by the icy weather. basically should i expect the washer jets to freeze up if its got screen wash in? (i'm guessing yes although....) also should the jets actually work or is there a set temp or something when they work?
the reason being...
i went for a drive today and at the start of the journey the washer motors wouldn't even whirr so i assumed fuses or motor. checked the fuses and none gone. at the end of the journey (and the reason i went for a drive in the first place
) the washer jets had thawed out and were working fully on both jets!
why? if it was so cold that the washer jets wouldn't even whirr then why did they start wotking again? is there a set operating temp?
the reason being...
) the washer jets had thawed out and were working fully on both jets!why? if it was so cold that the washer jets wouldn't even whirr then why did they start wotking again? is there a set operating temp?
