The last few days I have noticed a squeak noise, maybe more a tick, from the under the bonnet of my Focus 1.6 petrol MK1. It is quite loud when I start the car then it goes very, very quiet after 10-15 minutes or so.
I took it to a garage today and he looked at the fan belt, gave it some tuggs then poured some water on the belt and the noise stopped. He said don't worry about it, possibly the cold weather resulting in the noise.
The noise was not there last week before the cold and snow. Now the noise is very, very quiet to be honest but like a fly buzzing around your face that is harmless it can cause you zone in on it and get annoyed.
So based on what the mechanic did and the results was his advice correct? Or do I need a new fan belt or tightening fan belt? Even though mechanically it might be sound I find the noise irritating which a new belt might fix.
Thanks
Michael
Thanks
Michael
