I'm curious what you'd want a netbook for in relation to photography anyway...you're not going to fancy processing much on a traditional netbook spec machine and if you're carrying round serious photography gear then the extra weight of a 13' laptop compared to a netbook is fairly negligible...
To the OP, avoid netbooks if you want to shift your stuff over to a machine for photography. The Atom CPU just hasn't the clout for processing, and the onboard GPU will most likely be an Intel integrated affair if my two NC10's are anything to go buy.
Netbooks are lovely machines but if you're aiming to do anything serious then look at a Macbook as mentioned.
I have found the closest thing to a netbook Apple have made was the old 12" Powerbook. You can pickup the old 1.5Ghz G4 one for well under £300 (sometimes even £200) and they are pretty decent. Only downside is no Snow Leopard - but I haven't even bothered putting it on my MB yet, only my desktop.
A G4 laptop will be an absolute dog these days. I wouldn't buy one.
I remember seeing somewhere that when someone asked apple if they were making a netbook apple said that they were too small and didn't have enough power for conventional use (or something along those lines)
