Caporegime
- 18 Sep 2009
- Dormanstown.
Since some people seem to see need IBT stable screenshots.
1.375V at 3.8GHZ stable.
.run 10 or 15 at that, then you'll know it's fully stableLadies and gents, we now have 3.9GHZ on stock volts.
i can easyly do 5 runs at 3.9ghz on low voltage but at about run 7-8 it fails.Ok, since you're obviously not going to accept my overclocking, since even 5 run IBT
its because i upped the cpu-nb voltage up to 1.150vwhich is why you're now 1.425V stable at 3.8GHZ.
u have 12gb of ram thats why it takes a lot longer.. the more ram u have/use the longer it takes but gives better results u get20 minutes is nothing, I give you 15 loops in five hours.
2. Use the most available RAM possible (IntelBurnTest can now do this on
its own automatically). The more memory it uses, the more accurate.
from the Readme-IntelBurnTest
my ram passed memtest but i was getting random crashs so i underclocked them which worked fine, so i rma them, now the replacements are better, no crashs at 1600mhz 8-8-8 20 1t. even though it should be 7-7-7-20 2t but that crashs so they still not 100% right.but it passes memtest and should be pushed pretty hard by ibt.
