I have just built my new rig made up of the components listed below:
The problem that I am having is that I am getting noise from what I assume are some of the capacitors in the PSU especially in intensive stuff e.g. Crysis especially on the menu, but also when browsing the web more so when a download progress bar is in use. It is definitely coming from the PSU rather than the mobo or GPU.
To try and troubleshoot this I have swapped out the GTX 280 with an 8400 GS I have kicking about. The noise is still present. I first noticed it during the tests for the windows experience index.I have also swapped out the PSU with a spare Coolermaster Real Power M620. The noise is the same. The GTX 280 has been taken out of the rig in my signature which does not have the above issue.
Following a suggestion in another thread I have turned off Speedstep and C1E in the BIOS. This has not helped unfortunately.
While I was build my other rig (the Q9450 based one). I had a similar noise issue; the difference here was that the noise seemed to be coming from the Mobo. The fix here was to RMA the Asus Maximus Formula and replaces it with an Asus P5Q – Deluxe. The main difference here other than the chipset is that the P5Q has more power phases than the Maximus.
However I don’t think that the RMA will be successful in this instance as the POST indicator on the board says FF which indicates that it has posted successfully.
Can anyone think of anything else I can try or do I need to bite the bullet and change to an Asus P6TD or similar?
- Intel Core i7 920 D0
- Gigabyte GA-EX58-UD5 Intel X58
- Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C7
- Zotac GTX 280
- Asus Xonar DX PCI-E
- Antec P183
- Corsair H50-1
- 2 x Samsung SpinPoint F3 500GB - RAID 0
- LiteOn IHAS324-32 24x DVD±RW
- Be Quiet Dark Power Pro 550w
