Recommend me some active DJing speakers
29 Dec 2004
Shepley
Want to get back into using my decks and I'll need some speakers to do so! I would like some active monitors for less than £100 to hook up to my mixer (I use headphones for beatmatching). They will very rarely go above bedroom volume and I don't want a sub because I live in a flat with thin walls so the less annoying of the neighbours the better! Just some speakers that sound good and aren't too big- they need to fit on a desk so perhaps a little smaller than standard 'bookshelf' speakers. Can anyone recommend some? Cheers. :D
Check out SKYTEC STUDIO MONITORS.
You can get them for 60 quid on the bay. I've got them wall mounted in my little practice room and they're great.
