Spec me a way of buying ski boots!
18 Oct 2002
Ironing
In a little over a week, I'm going skiing in France for a week. This is not my first time, and I'm getting to the point where I can confidently get down pretty much any reasonable piste without falling over too much.
Once again, I'll be hiring my boots and skis and will therefore be running into a familiar problem: I have odd shaped feet.
For whatever reason, my feet are generally too wide, too deep and too lumpy and this makes finding a comfortable pair of boots a huge pain. More often than not, I've spent an hour finding ones I think fit in the hire place, gone out and swapped them after two hours because my toes have gone numb.
What I've been able to work out so far is that whilst I'm a size 9 in regular shoe-land, I'm a size 10 in ski boots, mostly to get the extra height above my toes.
My new plan is to buy some and never have to go through this again, but I have a dilemma: Do I buy in the UK and risk not being able to try them out until I haul them to France and find that they don't fit, or do I spent 300% more buying some on the resort, but at least know that I can try them that week and complain loudly at French people if they don't fit? Or is there some other sensible approach that's completely bypassed me?
tldr: What's the best way to buy ski boots if I've got odd shaped feet and tend to wait until I've actually been on the slope before I know if they fit or not?
P.S. If anyone can chuck out what I should be spending (roughly), that'd be great.
Perhaps buy some in the UK and then try them out at an indoor slope somewhere? I know indoor slopes are rubbish, but a few hours should give you decent idea if they fit properly.
artificial edit: actually, they might not accept them back after you've hammered them down a slope...
If you suffer foot pain / problems you need to go to a professional ski boot fitter. Tell them all your woes and they will advise what boot suits best, they will then mold the shape of you foot to the boot for maximum comfort.
Most ski shops have a good stock and someone employeed who knows what he's talking about.
Aviod buying over the internet, as you won't get the same service and will only save 10-20%, when you have sore feet for a week you would happily pay 200% more!
You will need to wear the boots for a good few hours prior to flying out and they may well hurt for the first 1-2 days while you break them in.
Having said that, i tried all the above and my feet still hurt! Took up boarding and it's much less painful :)
Good luck and have fun.....
Hmm i cant remember the company or where it was but my cousins got some ski boots custom made and moulded for his feet as he had a similar problem to you. They didnt cost that much more than a decent pair of boots as well. Maybe something like that would be the best option
Actually if you are near london there is a company who spend pretty much half a day analysing your feet and picking / molding the best boots. Think it costs about £300 for the privilege, but if they cant get you comfort no-one can.....
Go to a snow and rock shop and they will go through the whole process for you. Easiest way of doing it. You will be there for about 2 hours getting them sorted to make sure they fit properly.
If you aren't fully grown, i wouldnt bother buying a pair just yet, but if you are, then I would if you intend going every year as your skiing will improve no end!
Get some in the UK, you can talk to people and tell them your needs and requirements. I did this with my snowboard boots, you have the opportunity to try a few pairs on and discuss with the sales assitant the feel of them. As mentioned before I wouldn't buy them off the internet as you never know how they will fit.
P.s. when and where are you going? I'm going out to france on saturday.
I'd suggest going in the UK and actually spending some time with a decent shop to get them properly fitted, as mentioned you can get injection foam moulding for a completely custom fit.
Have fun.
I live in Ealing, so would be very interested to know of good places in / around London that do this. Also, do you know how long it takes?
I'm 26, so I don't think there's much growing left :p
I'm off to La Clusaz on the 9th.
The general impression I'm getting is (a) buy in the UK, (b) get them custom made (c) about £300. Anyone got any specific recommendations of shops to go to? Snow/Rock have already been mentioned, anywhere else?
Get yourself down to snow and rock or go to north america. I got my boots done whilst I was in whistler and they guaranteed the fit for life so well worth it!
a lot of the boot manufacturers do a custom fitting service for the inner soles, best bet is to get to your nearest indoor slope and the local store there should let you demo some boots.
The Xscape near me has an Ellis Brigham and when I got my new boots they had demo pairs of certain ones to try on the slope.
I was thinking of a place called Profeet as being just about the ultimate in fitting technology but I'm not sure if they could do it in time and it's not a cheap option.
Ellis Brigham also might be worth a look.
I was just looking at the Profeet option. I'm not an expert, so don't know if the price would be worth it. As you say, they might not do it in time. I'll check out ellis-brigham too.
*edit*: Oooh, there's one in Manchester, which is where I happen to be right now...
