oh u said fan but now i think u mean the heatsink/fan lol. Wd40 works a treat in removing the paste, but if your not overclocking u might as well use the stuff u get with ya new one.
I thought WD40 is the worst thing to use? leaves a greasy residue on the surface causing the paste not to get into the tiny microsopic holes.
when i clean i just use tissue paper thats it does the job
Stefan
Stefan
Get yourself some high purity Isopropyl Alcohol, had a can for years now and it is perfect for cleaning CPUs. As it evaporates it is perfect for cleaning of other electronics as well, motherboards, graphics cards etc.
WD 40 fills micro pouous surfaces so unless ur cpu and HS are super lapped you'd actually see increased temps as there would be hardly anyway to remove the man made oil from the valleys in the cpu and HS.
Whilst there might be better methods than WD40 for cleaning heatsinks I doubt it would make that much difference.
The heat paste would still be in contact with the majority of the heatsink base and its not as if WD40 doesnt conduct heat :\ Some heat conductive pastes probably dont even get into those micro sized pores so perhaps itll improve conductivity? lol
Either way unless someones actually tested this I wouldnt get my knickers in a twist over how to clean a heatsink
