- 5 Apr 2008
Hi,
I have an i7 920 watercooled with
black ice gtx 360 rad
d5 vario pump @ 4 speed
Watercool Heatkiller (HK) 3.0
My idle temps are 29 degrees when first turn on. But quickly rise to about 33 28 33 28.
Load temps are 38 when first turn on but after the pc is on for a few minutes it is about 40-42.
What do you think of those temps.
Remember these are the best watercooling components money can buy.
EDIT:
overclocked 3.8ghz 1.35v, idle is 37 (has been on a while) load is 59
Please ignore this next bit if you don't know, dont let this bit put you off replying!!
ps. I think my pump may have got louder but may be imagining things?
pps. I had some colour change in the liquid, got darker not lighter, probably something like chemicals in the rad. Emptied and replaced with distilled. Still bits of debris (dye probs) clustered in the top of res. Really small. Would little dye specs cause damage to the pump?
EDIT:
