Here is a list of my gear:
Antec P183 Case
Gigabyte EX58-UD5 Intel X58 Motherboard
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz
Corsair H50-1
Corsair XMS3 6GB PC3-12800C9 DDR3
Sapphire 5770 1GB New Edition
Corsair 1000W Power Supply
4 x 1.5 TB seagate 7200 RPM 32mb cache for storage
1 x Curcial M225 SSD (64gb for installing Windows 7 Home Premium 64bit)
Please can someone assist me in guiding how to overclock my system to 4GHZ. I mean I have looked around and found these settings is this a good option or does someone have a better settings? please consider all my equipment as stated above.. Here are the settings which I think may be good for 4 GHZ overclocking.. I want to get the best out of my RAM and CPU any advice and help is welcome. or shall I just use the Overclockers profile which they use for this setup?
SETTINGS SEEN ON ANOTHER FORUM:
Ai Overclock Tuner - Manual
CPU Ratio Setting - Auto
Intel (R) SpeedStep (TM) Tech - Enabled
Intel (R) Turbo Mode Tech - Enabled
BCLK Frequency - 190
PCIE Fequency - 100
DRAM Frequency - DDR3 - 1523MHz - If you use memory that is slower than 1600MHz, you can use the next lowest setting here, however, if you use faster memory, such as 1866MHz or even 2000MHz, please stick with this setting for now.
DRAM CAS# Latency - 8 DRAM Clock
DRAM RAS# to CAS# Delay - 8 DRAM Clock
DRAM RAS# PRE Time - 8 DRAM Clock
DRAM RAS# ACT Time - 24 DRAM Clock
CPU Voltage 1.25000v - This is our maximum Vcore
CPU PLL Voltage - Auto
QPI/DRAM Core Voltage - 1.3v - We need to up this to 1.3v to maintain stability, or at least I did on my CPU, your mileage may vary and you may need slightly more or slightly less.
IOH Voltage - Auto
IOH PCIE Voltage - Auto
ICH Voltage - Auto
ICH Voltage - Auto
DRAM Bus Voltage - 1.66v
DRAM DATA REF Voltage on CHA - Auto
DRAM CTRL REF Voltage on CHA - Auto
DRAM DATA REF Voltage on CHB - Auto
DRAM CTRL REF Voltage on CHB - Auto
DRAM DATA REF Voltage on CHC - Auto
DRAM CTRL REF Voltage on CHC - Auto
Load-Line Calibration - Enabled
CPU Differential Amplitude - Auto
CPU Clock Skew - Auto
CPU Spread Spectrum - Auto
IOH Clock Skew - Auto
PCIE Spread Spectrum - Auto
Antec P183 Case
Corsair H50-1
PCIE Fequency - 100
IOH Voltage - Auto
ICH Voltage - Auto
ICH Voltage - Auto
