windows live mail uninstall ?
18 Feb 2007
London
hi
im having problems with windows live mail in windows 7 , every so often i get a box appear that says " windows live mail has stoped working " and needs to close.
ive done the repair method threw add/remove programs and at first i thought it had solved the problem but it started doing it again.
my question is if i try a uninstall in add/remove programs will that remove all my email accounts and messages?
it will remove the email accounts you have, I guess there is a way to do a backup if you know where those files are?
your email shouldn't be removed, but you might as well back them up to be on the safe side - (Alt) File - Export
Save yourself some hassle and do this ^
I can't remember how WLM works exactly but if you get the option to export your contacts & calendars, do this also.
