Can it be used as TV?
Permabanned
9 Dec 2009
I've just orded a w2486l 24" moniter. I may be wrong, but as far as ILnow a moniter can be set up as a TV as well?
If so, what do I need?
Thanks.
Unless the monitor has built in tv, like my first link, then as far as I know a Usb tuner or internal card is the only other way.
I stand corrected as shown above. Maybe cheaper buying a monitor with built in TV! £130:eek:
What I mean by that is. On the back of that box, it's got the end you use a dish thing In.
We use a aerial what is a diffrent end to go into the box.
The bottom connector is an aerial connector.
"For an out of the box solution this works very well. Of course it relies on you having a TV aerial socket next to you PC, but aside from that everything worked perfected. What's even better about this unit is that it's self-contained "
