Isn't that decoding handled by most GPU's and IGP's?was ready to upgrade cpu anyway to something with a bit more grunt for watching .mkvs etc
Do you mean would an Athlon II X3 be better than an Athlon II X2, I doubt you could tell the difference?Wouldn't the X3 be better for playing media in Windows 7 than an Athlon II?
Afaik all meaty video decoding duties are taken care of by the GPU and IGP these days, you don't need a mighty powerful CPU anymore . . .
Euro Hunter, I had the same problem. In the end I ditched the CPU, which was a Socket 939 4200+, and dropped an Opty in.
Oooh, me likey! I have a nsk 2480 and would like to spray it black. Whats that in your lower 5.25" bay?
I also use a mini ninja in mine but with a intel e5200. Perhaps a silly question and you've probably tried it, had you tried to clean up the heatsink/cpu and put some new thermal paste down?
In my lower 5.25 bay I have a 'imon inside' which is a remote control receiver which also enables full system on/off via remote![]()
Well I've installed it and it doesn't look too bad. Shame the front bezel has got a bit bent somehow under the drive bays though.
