iirc the NiMh batteries have to be discharged first to avoid damage. It all gets a bit involved.
Why isn't this talked about more then? Surely the batteries get low on charge, so just charge them up overnight...?
You would think that but if you do that with Ni-Cad or Ni-MH they develop a memory and they see that point as dead so thier life becomes shorter.
Lith-Ion batteries don't suffer from that problem but they are stupidly expensive
Im very suprised at that. It should charge to near the maximum capacity even when trickle charging like you are. The 2nd charger down for £12 seems perfect for the money though.
http://www.component-shop.co.uk/html/body_standard.html
I was referring to a fast charge, C/3 or more. Clever chargers can discharge cells and terminate charge at capacity to avoid damage.
So in the case of the Uniross Easy Charger I've just purchased?
That sounds a bit rubbish then?I would say that just runs on a timer, you need to manually calculate how long to leave the batteries on for depending on how much charge they have left in them and their capacity. (the charger outputs a Charging Current: 350mA)
The timer is usually a maximum timer safety cutoff, so you really have to do everything manually.
You also have to charge in pairs, you can't just charge 1 battery with that charger, you need 2 batteries that have roughly the same available charge and exactly the same capacity.
Fine if you are using something with 2 or 4 batteries that you use occasionally and always run down before charging.
My charger (see post above yours) doesn't seem to imply it will cut off when they are full... Seems to imply just uses a timer?
GP ReCyko rechargeables are supposed to hold 90% of their charge after 6 months of standing and 85% for a year. I bought these on that selling point and after a month they don't seem to have lost anything. They claim they can take a few more charges than the competition as well, which prolongs their lifetime.I find the main problem with recharageables is the discharge rate when they are not being used. Got some duracell rechargeables and they are absolutely terrible. Go flat in a few days just sitting on the desk!
Sounds correct. The one I linked to however cuts off when the battery is full. Really is something you need to look for in a charger to get the maximum from your cells.
Yup, the important part is this line.
"-dV detection (shuts down when it senses full charge is reached)"
