Hi All,
Just moved into a new pad in London, where the developers clearly had a deal with all the major energy suppliers to fit as many spot lights into each room as possible ! As a result, every time I turn on the lights the owners of the decommisioned battersea powerstation across the road keep asking if I want them to start it back up !
Anyway, I digress.
I am a little bit baffled by all the choice for either LED or 'other' replacement bulb options. Some seem to cost £2, others quite literally £16 per bulb.
I have two 'normal' bayonet bulbs in the hallway and they are almost instantant (quite literally 2-3 seconds) and they are at full brightness which are 11w energy savers.
Has anyone here replaced their GU10 bulbs with anything that doesnt cost £16 per bulb and turns on to full brightness/80% within 5 seconds?
Anyway, I digress.
