i7 cooler for overclocking to 4Ghz+
Permabanned
31 Jul 2008
Manchester
Right guys i am after a cooler that will take my i7 920 DO to 4Ghz+ and be stable.
I was looking at the Noctua NH-D14 as it seems to be the best (even better than the Corsair H50) but its hard to find.
It is also MASSIVE, would it warp my board ?
What would you guys recommend ?
Looks heavy and cumbersome...
I'm using a H50 and i'm 4.2GHz stable with no cores going over 75c on max load.
If you want the best get the Nh14 as it beats all other air coolers and the h50 by a considerable margin.
I think if Ock sold them there would be a lot more threads about them.
There are some due in 4 days time at a competitor.
if your case big enough and your ram got the clearance get the ND14 if not get the megahelems its a lot smaller and fits nicely in most cases and you dont have to worry about ram clearance.
