I've been reading through formfactors and can't get very far with this, so I thought I'd ask ocuk. I'm told I phrase things bizarrely, so I'll summarise the question: Could I run an overclocked i7 motherboard using a "pico psu", with the 8 pin atx and pci-e cables coming from a different (not pico) atx psu?
A common atx board has an 8 pin atx cable and a 24 pin one. It also supplies current to expansion cards, iirc a pci-e x16 slot is rated for 75W, and to peripherals. An overclocked i7 processor is generally considered to draw around 200W. However some fraction of this is through the 8 pin cable, and it's unlikely that a graphics card will draw 100% of 75W from the board when it has its own cables as well. What current does the 24 pin cable need to supply (estimates or a function of installed cards would be good)? My guess is 100W + 70W per pci card but I base this on nothing whatsoever.
The vast majority of current drawn by a computer is at 12V, however some is at various lower voltages. A pico psu takes 12V dc, has a stab at cleaning it up, and connects directly to the 20/24 pin socket which is the only place lower voltages are applied. I'm pretty certain, though I haven't checked, that the pico psu will run from any 12V source with enough current behind it. Say, a spare pci-e line.
It may then be possible to run an entire desktop computer from a single (high current) 12V line rather than from mains AC. This could be useful. At least, I can imagine uses for it.
I suspect I need to buy a multimeter and measure the currents running through each wire myself, but I also suspect this will be tricky as the only approach I know of is connecting an ammeter in series, so cutting a wire, measuring, attaching it back together. Any and all thoughts welcome.
Cheers
Cheers
