Titan goliath corsair h50 idle temps not dropping
18 Oct 2009
Edinburgh, Scotland
i just got the system back and ran p95 to see the temps after rmaing twice
so i stopped prime 95 as it was getting that high , now when i first started the pc up it was at 40ish idle but after stopping prime 95 check my temps
this is in the antec 1200 case , push pull at the bottom rear 120mm fan , this system has just been a nightmare. i regret buying it QQ
Yeah way to high. I wouldn't worry about idle temps, but I would worry about load. Try reseating the h50, or replace the thermal compound. You may put too much or to little compound on the cpu. If you are using the stock compound that came with the cooler, remove and buy some decent compound such as, MX3
those temp are way to high!!! if i was you i wouldnt be happy at all
im not , i requested that they replace the corsair h50 normal tim with as5 but i doubt they done it , i also asked if they could install the rad and put the 120mm on it but it was just lying in the box. my cable management is also a lot messier because i guess they had to take of the mobo to put the plate on for the corsair h50
im close to just getting a refund its been a total nightmare
I think you'd be better off doing it yourself. Just use some ArctiClean (or equivalent) and reseat with some arctic silver 5 or MX-3 compound. If you do it correctly it should be absolutely fine. It sounds like they rushed the job if your cable management has gone kaput as well.
Should send it back imo, you'd expect it to come back in the same condition it first reached you, cables tidied properly. Get on the blower to them.
Post a pic of the internals to see how bad it is.
You will find that the corsair paste is very decent will be minimal difference using mx3 as good as it is. liam get in touch with Dabyboy think he had a duff mega hot chip that he got replaced
Make sure they clean the cabling up, can you post a pic of it?
its not as bad as i made out , i was just really angry. i tucked the wire behind the hdd bit.
i really hope they fix it this time , had the pc for like 1 month and barely played anything
