BF Goodrich. 4 by 4
One of the best. Their A/T tyres are great all-rounders and last forever.
Once you start to get in to needing MT's then you might want to consider other brands as well.
They are expensive, but very very good.
Generally regarded as the best 4x4 tyre (AT or MT) around but they are expensive, but you do get what you pay for.
If you want a tyre for a 4x4, there are plenty of makes around, Kumho and Cooper do good tyres as well.
It all depends what you are going to use the tyre for.
Kinger
BFG's as said are probably the best AT and MT tyres around, they have good road manners, excellent in the sticky stuff and the wear rates are superb, they last and last and last.
Yup, bfg's are prety good. Might want to consider General Grabber AT2's (bfg clone) slightly cheaper and has much to be said for them over at one of the LR forums. I have a set of 4 Cooper Discoverer S/T on my 300tdi discovery; Seem to behave themselves on the road and in the snow and ice recently.
But if work are paying, go for the BFG AT's. :p
echo the thoughts above, after using dueler's for a couple of years I got a good deal on some bfg's and never looked back. When you factor in the better wear they don't work out too bad.
I have a set of 33" BF Goodriches on the back of my Baja. Loads of traction off road, however VERY slippery in the wet on the road.
Would love a matching set for the front, however will have to be slightly smaller. They're hard to get hold of though without spending big money.
