For my first build I did. It basically just got in the way.
About 20+ PC builds later and I haven't used one since then. I haven't had any problems, I just touch a grounded radiator (an unpainted part) before starting and everything is fine.
I repair PCs and laptops as a field engineer. If I didn't use one I'd get fired - no argument. I can't understand why people find them such a hassle to use.
just install the power supply, and have the cable plugged into the socket and input on the power supply (switch the socket off), and every so often touch the case. that way you are grounded without buying a anti-static wrist band
