How do sticky grenades work?
http://worldwartwozone.com/forums/personal-combat-weapons/6614-the-sticky-bomb.html
Even as it was first introduced, the Sticky Bomb was considered as dangerous to the solider using it as it was to the enemy. Designed as a portable anti-tank device, the Sticky Bomb was an explosive charge, separated from a thick, sticky glue by a thin glass sphere, and all contained in a slightly thicker glass casing with a milled handle containing a five second fuse.
The idea was that when confronted by a tank, a solider could either pull two attached rings and toss the bomb at the tank. Or for insured adhesion, pull a safety ring first then and by holding the handle, smash the outer casing against the tank, then pull the fuse pin.
