It is indeed, and I would be thrilled to help you in your endeavours. However it is not practical, or even possible, to do so if you will not take the time to learn the basics yourself. At the very least you should find someone with similar hardware to you and look at the numbers they've set. Not one of them will be using anything like 1.5V for 4ghz, for reasons that should be obvious to anyone who has read a faq.
The lazy approach is to copy the settings from someone who has done the hard work for their system, then tweak them to get it stable for your hardware. However for this to work you still need to spend the time googling the various words found in the bios, and reading a thread on stability testing.
Perhaps you are correct that I could be more helpful, or at least more tolerent of your reluctance to use Google. As an apology. these are the settings I use for 4.0ghz using a ud5, 920, 6gb of 1600mhz ram. These are unlikely to be stable for you, you *will* need to stability test and tweak the settings.
Stable settings
Initial, known stable from previous efforts.
Code:
200x20, turbo off, HT on
6gb v3.2 @ 1600c8
vcore 1.3
qpi 1.295
vdimm 1.64
Code:
[u]Advanced cpu features[/u]
[b]Clock ratio 20[/b]
Turbo disabled
Cores enabled all
Multi-threading enabled
Enhanced halt (C1E) disabled
C3/C6/C7 state support disabled
CPU thermal monitor enabled
CPU eist function disabled
Virtualization tech enabled
Bi-directional prochot enabled
QPI link speed x36
Uncore frequency x16
Isochronous support enabled
[u]Advanced clock control[/u]
[b]BCLK 200[/b]
PCIe 100
CIA2 disabled
CPU clock drive 700mV
PCIe clock drive 700mV
CPU clock skew 0ps
IOH clock skew 0ps
[u]Ram[/u]
Performance enhance standard
XMP disabled
System memory multiplier 8
DRAM timing auto (8-8-8-24-2)
[u]Advanced voltage control[/u]
Load-line calibration disabled
CPU vcore 1.3
QPI/VTT voltage 1.295
CPU PLL 1.8
PCIe 1.5
QPI pll 1.1
IOH core 1.1
ICH I/O 1.5
ICH core 1.1
DRAM voltage 1.64
DRAM termination/vrefs auto
The source is the thread found
here which is a reasonably detailed record of how I am attempting to overclock my system. I hope you read through it, as it is intended to be helpful. I apologise for the erratic formatting, I can't turn it into a guide until I've worked out some freezing which I think is turbo related.
