Colelagues,
We now have a full selection of DDR2, DDR3 & SODIMM Hyperx Dual and tripple channel kits available for order.
*** *** Kingston HyperX 2GB (1x2GB) DDR3-15000CL8 1800MHz (KHX1800C8D3/2G) @ £45.99 inc VAT *** ***
Kingston's 256M x 64-bit 2GB (2048MB) DDR3-1800 CL8 SDRAM (Synchronous DRAM) memory module, based on sixteen 128M x 8-bit DDR3 FBGA components. This module has been tested to run at DDR3- 1800MHz at a low latency timing of 8-8-8-24 at 1.7V to 1.9V. The SPD is programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. This 240-pin DIMM uses gold contact fingers and requires +1.5V.
- JEDEC standard 1.5V ± 0.075V Power Supply
- VDDQ = 1.5V ± 0.075V
- 667MHz fCK for 1333Mb/sec/pin
- 8 independent internal bank
- Programmable CAS Latency: 5,6,7,8,9,10
- Posted CAS
- Programmable Additive Latency: 0, CL - 2, or CL - 1 clock
- Programmable CAS Write Latency(CWL) = 7(DDR3-1800)
- 8-bit pre-fetch
- Burst Length: 8 (Interleave without any limit, sequential with starting address “000” only), 4 with tCCD = 4 which does not allow seamless read or write [either on the fly using A12 or MRS]
- Bi-directional Differential Data Strobe
- Internal(self) calibration : Internal self calibration through ZQ pin (RZQ : 240 ohm ± 1%)
- On Die Termination using ODT pin
- Average Refresh Period 7.8us at lower then TCASE 85°C, 3.9us at 85°C < TCASE . 95°C
- Asynchronous Reset
- PCB : Height 1.180” (30.00mm), double sided component
Only £45.99 inc VAT.
ORDER NOW
*** *** Kingston HyperX 2GB (1x2GB) DDR3-12800CL9 1600MHz (KHX1600C9D3/2G) @ £43.99 inc VAT *** ***
Kingston's KHX1333C7D3/2G 256M x 64-bit 2GB (2048MB) DDR3-1600MHz CL7 SDRAM (Synchronous DRAM) memory module, based on sixteen 128M x 8-bit DDR3 FBGA components. This module has been tested to run at DDR3-1333MHz at a low latency timing of 7-7-7-20 at 1.7V. The SPD is programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. This 240-pin DIMM uses gold contact fingers and requires +1.5V.
- Posted CAS
- Programmable CAS Write Latency(CWL) = 7(DDR3-1333)
- 8-bit pre-fetch
Only £43.99 inc VAT.
ORDER NOW
*** *** Kingston HyperX 6GB (3x2GB) DDR3-12800CL8 (1600MHz) Tri-Channel (KHX1600C8D3K3/6GX) @ £135.99 inc VAT *** ***
Kingston's KHX1600C8D3K3/6GX is a kit of three 256M x 64-bit 2GB (2048MB) DDR3-1600MHz CL8 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 3GB. Each module kit has been tested to run at DDR3-1600MHz at a low latency timing of 8-8-8-24 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.
- Posted CAS
- 8-bit pre-fetch
Only £135.99 inc VAT.
ORDER NOW
*** *** Kingston HyperX 4GB (2x2GB) DDR3-8500CL5 1066MHz SODIMM Dual Channel (KHX1066C5S3K2/4GX) @ £93.89 inc VAT *** ***
Kingston's KHX1066C5S3K2/4GX is a kit of two 256M x 64-bit 2GB (2048MB) DDR3-1066MHz CL5 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Total kit capacity is 4GB. Each module kit has been tested to run at DDR3-1066MHz at a low latency timing of 5-5-5-15 at 1.5V. Each 204-pin SODIMM uses gold contact fingers and requires +1.5V.
- Posted CAS
- 8-bit pre-fetch
Only £93.89 inc VAT.
ORDER NOW
*** *** Full Kingston HyperX Range *** ***
- Posted CAS
- 8-bit pre-fetch
ORDER NOW
- Posted CAS
- 8-bit pre-fetch
ORDER NOW
- Posted CAS
- 8-bit pre-fetch
ORDER NOW
- Posted CAS
- 8-bit pre-fetch
ORDER NOW
